Inline6359
- -1
- 6
- Pa
Now first let me State I have searched. And I’m not finding exactly what I’m searching for.
I know there are a few options out there, mrap, and 5 Ton fronts, full air. When I bobbed my deuce there was a plethora of after market parts out there, saddles, perches, blocks, hangers, etc. with the 5 ton I’m coming up blank on most of this besides oem.
The problem arises because of the direction I want to go with the truck. I’m basically looking to build a 5 ton dump. I found what I believe is a good deal on an m931a2. But, I can’t imagine 5 ton springs are up to the task by themselves.
This is brings me to my few options. And I’m looking for input as I want this to be a safe 5 ton dump, hence right now the spring options are my limiting factor.
Here are the options I have come up with, any input is greatly appreciated.
Buy a factory 5 ton fronts and have my local spring shop ad leafs, they admitted then can do this but can’t tell me exact rates or specifics, just they they can add leafs, or remove leaves and ad thicker ones. Not a terrible plan but not as precise as I would like to be.
Take me my local spring shop the exact measurements of a 5 ton spring, and see if they can come up with a spring close to the same measurements with my desired rating, since I’m bobbing length isn’t an issue.
Or mrap front springs. I have seen them in a lot as advertised as 20k but have no idea if this is accurate, nor have I seen much feedback how they would do with 10k on them plus the weight of the truck, I.e flex and ride quality loaded.
Im trying to figure out this hurdle before I pull the trigger on this truck, if I can come up with a good solid option then Ill probably pick the truck up.
