Another Bobber!
BigWheelBob
Muskegon, Mi
Got up early this morning, got the frame stripped of all the rivets, and bracketry. I then rolled the axle and tires off the 105 trailor under to get placement. With all the weight on the rear, it looks like the rear sits about 2-3 inches lower than the front. I am sure the rest of you bobbers have ran into this also. What did you do to level the truck up? Lower the hangers? Add a block to the rear? I understand when I put the actual rear diff under it, I will probably gain a little of the lift back, but not as much as I need. Thanks, Bob.
