Another solution to Non-returning/non-resetting windhield wiper arms
86M10086.2L
Long Island, New York
If you are like me and the windshield wipers on your truck operate properly in all other functions but simply don't return or self park when shut off. Give this a try. In my case simply cleaning the outside electrical connections or checking grounds didn't work. I started by taking the connectors off the motor assembly, popped off the dust cover. Removed the parking switch/washer switch assembly from the top of the wiper motor. (look for a small plastic tab on right side of the assembly next to the coil) Cleaned the "points" style contacts on the back of the switch. Mine had some builup/oxidation on it. This is what actually controls the park function. That contact runs along a ramp on the wiper motor gear and stops the wipers when they return to the parked position after being turned off via the switch on the steering column. I also took this time to clean the assemlby up. Removing all the caked up and dried up grease (which can also be a cause of this failure), checking spring tensions, and giving a thorough cleaning of all the contacts. Re-assembled in the reverse order and your done. Please note, that if you don't reset the windshield washer switch to the neutral position on the plastic cam/drum located underneath the switch assembly. (by putting the metal arm on the front of the drum face. Your gonna go through one complete cycle of the windshield washer. This procedure worked well for me and may work for you also. It's free, takes very little time 20-30 minutes tops and didn't require buying a new motor assembly. Just thought I'd share.
