Another tire question on bobbed deuce?
TJP
PHX/AZ
I would like to put 1600R20 on a bobbed deuce.
1. Do you have to use a lift kit.
2. If you do does any one make the kit.
3. Can you use stock wheels with 1600R20.
4. If you can is it dangerous.
5. If you can't what wheels can be used.
6. And last if any one has put 1600R20 on there bobbed deuce any pics would be great to see.
THanks
Jimma
Hartwell, GA
Good answers Westech. Also you will have steering clearance issues with those tires on the front. Even with the smaller 395's on stock rims you will have some rubbing on tighter turns. The 395's work fine but when you turn hard they may scrub some.
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Someone has said they are working on a kit, but it is not available yet. Pics are around here somewhere.
