Any reason this will not work???
devilman96
Boca Raton, FL
I am working on some technical drawings for electrical mods, 12 conversions, ign switches, lock outs, etc... I thought it would be a cool thing to post for other people whom might need the reference...
This one is for installing a keyed ignition switch which would replace the OEM start button and accessory switch...
Anyone see any problems with combining wires 1 and 27?
cranetruck
74
Meadows of Dan, Virginia
Wire #1 is the generator output and goes to the regulator on the units with a separate generator/regulator set-up.
It goes through a resistor which monitors the current and an SCR (solid state switch) within the regulator and should not by combined with anything else if you have the two separate units.
Need to check on the alternator wiring for the numbers there.
devilman96
Boca Raton, FL
Do you have a good scan, pic, or can point me to a TM & page showing the 2 piece system? That way I can resolve the issue for ether set up by doing diagrams for both...
In the original diagram I can see why you would want to keep 74 and 1 apart so that current and switching was not an issue when starting but other wise I cant see a hitch in the revision?
