Anyone use headlight polish on the gauges?
mgFray
992
Southern Minnesota
All of my gauges are very scratched and 'fogged up' (not moisture).
I was wondering if anyone had bought plastic headlight polish and tried to sand and polish the gauge faces to make them readable again. (Ya I know I can buy new gauges easily enough, but the ones I have are working fine.)
Maxjeep1
1,930
Las Vegas Nevada
Mine were really bad and I was going to replace them anyways so I thought I would try to polish them before I removed them. I wiped them off with a paper towel that had carb cleaner on it and then I hit it with some aluminum polish that’s blue in color and in a short container. The sticker on the Speedo was the biggest improvement. I will try to add pics838ED16F-14F7-46EB-BB99-81E706A49806.jpeg01A04C71-4D41-43C8-84BF-5E30ADF92023.jpeg1BEA0F8B-6801-4250-BC11-7E2C26180D6C.jpeg3DB2DE11-16BD-48B4-88C3-FD373CB64626.jpeg
mgFray
992
Southern Minnesota
wow.. I think I'll try it then.. tired of the littlest bit of glare and being unable to read all of the gauges (except oil pressure which brand new)
Maxjeep1
1,930
Las Vegas Nevada
I just spent a few minutes on it. I will go back over it with the headlight polish and it should look new
kendelrio
9,296
Alexandria, La
Mine were really bad and I was going to replace them anyways so I thought I would try to polish them before I removed them. I wiped them off with a paper towel that had carb cleaner on it and then I hit it with some aluminum polish that’s blue in color and in a short container. The sticker on the Speedo was the biggest improvement. I will try to add picsView attachment 847398View attachment 847399View attachment 847400View attachment 847401
The results are amazing! Do you by chance have a name for this polish?
Maxjeep1
1,930
Las Vegas Nevada
9.95 harbor freight sells a headlight restoration kit and it goes on a drill and it will bring anything back to life… I used it on my exterior lenses and it works amazing.
20,660
I used the low-tech method of toothpaste polish followed by wax. It worked pretty darn well for my gauges
Toothpaste works really well.
Especially the old time Colgate - plain old white toothpaste in a tube. Not the jell stuff... The white paste.
mgFray
992
Southern Minnesota
I ended up using the combination of mag wheel polish and the plastic cleaner/polish after. It worked wonders to both the gauges and external lights.
While I can't say they "look like new", I can say that they're no longer foggy. The rag when I was done with just the gauges had this nasty brown stain on them, so it really did work well.
