Appels bobbed 5 ton
Nonotagain
Parkville, MD
Hey guys ..... here is some pics of my 5 ton i just finished today. I still need to mount mud flaps on the rear and minor adjustments on other things...... alot easier than a deuce.
How was bobbing a 5 ton easier than bobbing a deuce?
I'm looking at both options right now myself, so I'm interested in your experience with this task.
TW.
Nice looking truck BTW.
jcappeljr
27
Delta, PA.
Regular 105 bed,Its easier because no rivets bolt on suspension,no frame cutting,no air line removal,no hitch remounting,no sub frame under bed.half as much work,twice the truck.
dm22630
42
Front Royal, VA 22630
Do you think that the rear tires will hit the bed???? Looks mighty close!
So did you pretty much just unbolt the tractor parts, remove the rear axle, slide the middle axle backward & set it on 5ton front springs & extend the driveshaft?
How did you fix your sprag problem?
Looks great! :)
jcappeljr
27
Delta, PA.
dm22630,Thats exactly what I did,Tires will not rub,plenty of room for tire movement.Didnt fix my sprag problem yet.Still have to figure correct tire pressure.
dm22630
42
John -
I am running 60psi on the front & 50psi in the rear on my M813 w/1600s. I am going to pump the front up to 75psi....it is still loose on the steering.
How long did that take you to do? A day or so?
What hardware is needed to bob a M818?
Thanks!
Daniel
grounded
Banned
928
defiance oh
hey what about putting a front driveshaft in place of the front rear shaft? its longer wonder if you can measure see if it has the proper measurements? if it does then Daniel i have a drive shaft that you need also ;)
Don needs them springs off the 105 so you guys got it made ;) and you have some extra 900s ;) do it do it lol
