Appropriate method to SRW the deuce?
1,827
Yep, thats how the Gov't does it. Note the 11R20 radials which ride real nice. Not too gnarly looking though!
Loose Deuce
South MS.
Wouldnt they look better if they were turned out the other way? Or would they be sticking out too far?<img src="emoticons/icon_smile_dork.gif" alt="Dork">
hot rod deuce
Kasota, Mn
that would prolly load the wheel bearing more to one side if they did that. i could use that fleet at my house. Did u see all the nice pre-camo-ed deer stands on the first page<img src="emoticons/icon_smile_cool.gif" alt="Cool">
Trango
23
Boulder, CO
Thanks for that, Kenneth. I think this doesn't look so bad, and I'll be doing this as soon as the time and funds allow.
Cheers
Bob
Dieselsmoke
CA/NV
Jack Lee owner of www.milveh.com converted his truck to single, says it's the best thing he's ever done to the truck. Now if only he'd throw some nice big Michelins on instead of them dang civvy tread things he's got on there<img src="emoticons/icon_smilie_bitchin.gif" alt="Bitchin">
Longhunter7
9
Northern Illinois
Dieselsmoke!
The Super Singles are the best thing since sliced bread! <img src="emoticons/icon_smile_cool.gif" alt="Cool">
With the lock-out hubs and the singles, I can do 60 mph with no problem! <img src="emoticons/icon_smile_thumzup.gif" alt="Thumb Up"><img src="speech/icon_speech_yeah.gif" border="0">
Trango
23
Boulder, CO
Hey guys,
Two things:
1. Off the top of my head, I don't know if you need to swap the bearing races in the hubs when you flip. I ended up not flipping the hubs on my project truck's front axle, so I never had to flip. Can I just unbolt the drums and swap the bearings themselves around or do I have to flip the races as well (inner to outer and vice versa)?
2. I saw some M1070's yesterday on 16r20's. Those are INSANE.
Bob
solar powered
Originally posted by Trango
Hey guys,
Two things:
Bob
No, you can't switch the bearings around. The I.D. on the inner most bearing is larger than the outer one.
The front axle is the same set-up as the rear (Same bearings).
So, I would mount the rims like the picture posted and call it good.
Bill W
47
Brooks,Ga
If you can get a copy of Military Vehicles Magazine Issue 79 ( May 2000 ) theres a great step by step article in there on flipping the hubs to make SRW on the 35.
ironhorsethegeneral
11
Acworth, GA
The inner and outer bearings are different but the bearing races are the same. You can flip the hub around punch out your lug bolts and put them in the other direction or if you feel like spending a little money buy 4 front wheel drive hubs 2 left and 2 rights,right hand threads. Take off the brake drum from the plate and use as is. Bolt on your regular rear drums and shove them in. All front wheel hubs and rear wheel hubs are all the same part. Just reconfigured differently. This is what we did. Hope it helps.
Trango
23
Boulder, CO
Yep this is what I'm asking. :)
I hate punching out races from grease filled bores (my procedure is to always clean the grease out first, and that would be a heck of alot of snot from these hubs), so if I can avoid that then this job becomes much more attractive in my mind!!!
Thanks for the tip. I think this winter will see alot more work on the deuce.
Cheers
Bob
