Are all dump beds the same?
Vintage iron
Falmouth Ma.
I am interested in putting a dump bed on my M813, but I can't find any in New England. I have found some older deuce and 1/2 dumps in OK shape. are all dump beds the same Or are the 5 ton dump more heavy duty? They all look the same? What should I look out for?
KsM715
142
St George Ks
If its the complete set up (pump, res, cylinders and all) the PTO drive for the pump will be on the wrong side. I dont know if they can be moved.
R Racing
St. Leonard, MD
I looked into doing a dump on my M813 and after a long talk with a local installer , They said the aftermarket dump kits for the deuce are near max output. And you would not be able to use the 5 ton bed to its capacity unless you were hauling multch . They recomended a larger kit .
NickAir
10
NW OREGON
Just for liability you may want to consider the 5 ton version. If you even care about liability. Not sure of your application of use.
