- 10,350
- 74
- 48
- Meadows of Dan, Virginia
To be on the safe side, I thought I'd ask...
Drained the automatic transmission yesterday (xm757 Allison), replaced the filter element and refilled with the same amount of fluid, 5 gallons.
My question relates to the "Safe to start" level, before draining, the level was right on the mark, but after refilling it ended up above the mark by about an inch.
I understand that the filter housing and all the passages within the transmission may not be filled, so is it safe to start or should I drain some and fill more after running it?
It's been 18 hours since refilling.
