cosmic339
- 0
- 0
- Watertown, NY
Hello everyone, haven't been on here for a while. Finally going to get started on my project next Month. I decided that i want to order both axle for the front and rear. They would both be dana 60s . I figured I would try to keep as much of the original look of the truck. Today i was able to measure the distance between the center of the leaf spring to the center of the leaf spring and got 29"inches. When i called to order the axles i still need the WMS to WMS. Right now im unable to get a accurate measurement ( taking the wheels off, the truck is still buried in snow). I wanted to know
Does anyone know the actual WMS to WMS?
Im going to be fitting custom Humvee wheels, I read that I should order the axle's 4 inches wider than the WMS measurement so I have room to play with. I dont want the width to look wider than stock, would like to keep close to the stock width.
for the drive-train im going with a 4bt , nv4500 and np205 married setup . the gears will be 4.10. Have a bit of money to spend on this project.
Here is my current picture.
Any information would be great.
