axles help
Corey
5-ton Hydraulic brake bearing hubs are drilled for drive flanges on the inside like 2.5 ton hubs, they can be flipped. Air brake hubs are cast so they cannot be. I sold two front axles assemblys to a guy and he flipped the hubs, but is using custom pinion disc brakes, monster truck style.
KsM715
Corey, So are you saying on say an M818 with air over hydraulic brakes the front hubs can be flipped? Wonder what that would look like with the HEMTT wheels mounted reversed on the front?
USMC6062
Yes the front and rears can be flipped either way on hydraulic brake axles. The races are all the same part number, but I swapped races when I flipped the rear, because I'm reusing the bearings. I've always been taught to keep bearings with there races once they've been used. If somone wanted to, they could just flip flop the bearings, studs, and seal and put the hub back on the oppisite from what it was.
Sheldon, there will probably be some interference between the back of the wheel studs and the studs that secure the spindle to the knuckle. You may have to switch to bolts on the spindle and then shave some off the back of the wheel studs. I've never studied the 5 ton for the flip before.
Corey
Here is the backside of a 5-ton hydraulic bearing hub next to an air brake hub. Recovry4x4 is correct, you will need to replace the spindle studs with bolts so the wheel studs don't rub. You would also need to add custom disc brakes.
USMC6062
You can keep the studs that mount the spindle on, unlike a 2.5 ton where you have to change them out for bolts. Go on Chuckstrucks.net, a ton of people are running 5 tons on there and flipping hubs and such.
