Asmoday
- 0
- 16
- Los Angeles, CA
Hello all,
So while under the M1009 yesterday to replace a speedo cable and front emergency brake cable I decided to take a look at the trans mount bushings on the cross member for the trans/transfer case. Ever since purchasing the vehicle last November I have noticed a clunk when I drive over a certain king of bump or dip in the road. I originally thought the transfer case was hitting some carriage bolts that where hanging down into the trans tunnel area from whatever the army mounted there at some point and after removing them a while back the clunk got better but was still there.
So after checking the mounting pads on the cross-member and deducing everything looked fine I started looking elsewhere and behold I found the issue...
The transfer case is hitting the trans tunnel. The upper right portion of the the transfer case above the speedo drive assembly is actually resting on the sheet metal of the tunnel. There is a portion of the transfer case that looks like a little step and it's laying right against the tunnel floor.
I have attached a pic with a arrow showing the contact area...
After looking closely at the drive train underneath it looks like the whole drive train is shifted to the right somewhat.
Where should I begin to try and fix this issue?
I was getting ready to do motor and trans mounts anyway so maybe that's a start.
