Bad sprag...driveable?
Lorax
Hampton Virginia
OK, posting this for s friend with an 816. There is suspicion that the 816's sprag could be bad. Apparently, one day there was a loud BANG noise, and now when driving in soft dirt/mud and trying to turn, the front wheels don't turn the truck...the truck just plows forward. Now, this guy and his brother have owned this 816 for a number of years, and they know about the "don't roll backwards in N/1st, and don't roll forward in R" deal. The thought is the sprag may have gotten stuck while backing up and didn't release when going forward.
So here's a couple questions:
1. Is it OK to drive the 816 if the front driveshaft is removed until the sprag can be repaired/replaced?
2. Is there a way to test if the sprag is indeed bad?
Thanks
jwaller
19
Columbia, SC
it's fine to drive but to be safe remove the front driveshaft.
there are lots of tests for the sprag. a search will net them for you.
Westech
CPL
6,104
211
cow farts, Wisconsin
My sprag wend crap on me too.... the front sprag is locked on. I took the shaft out and its not all that bad of a job to swap out the front sprag and out put shaft. like that was stated.. take out the drive shaft and drive her.
pctrans
19
Bradenton, FL
Jack up all axles, spin the rears, and the front should kick in after 1.5 turns (make sure you have air).
