Battery switch
cundupa
Holland, MI
I think I'm having trouble with the battery switch on my M817. It has 4 terminals, 1 hot 3 switched. When I turn it on only the 459 wire gets power, goes to the control box. The wires, 54, to the fuel solenoid and starter switch are dead. I put a used one in and it does the same thing, both bad? If I cross the solenoid at the starter it will start and run most times. Must back feed something and wake it up.
Any ideas out there?
Ridgerunner
Holland, Mi
Dang, the other switch didn't work for you huh... I hate when that happens.
You can check the switches to see if they are good, with a ohm meter, to see if the contacts are opening and closing when operating the switch. It will give you some place to start your trouble shooting, to atleast see if the problems in the switches.
cundupa
Holland, MI
Found it...couple of wires in the wrong terminal on the switch. Wiring diagrams sure help. I guess I will need to pay you for the switch after all Ridgerunner.
