big problem. need any kind of help
biggen
jefferson, ga
1 big problem, and 1 small... frist off when changing belts on nhc 250 loosen water pumb and both wide bolt broke off right at thread. i am pretty sure easy out not going to cut it and hoping not to drill out and re thread, any help . i mean any help would make my day go better........then 2nd i cant find anyone the carry the water pumb belt nor a copper gasket, any one know where i can by them at ? thanks.... likei said any help what so ever would help me out
73m819
314
gainesville, ga.
try slacks truck parts here on gainesville for the pump ring, good bet belts as well, there is a cummins parts as well as a few good BIG truck dealers in town also
73m819
314
gainesville, ga.
yep, pull the rad, then if you can, weld a nut to the broken bolt/bolts, weld INSIDE the nut to the top of the bolt, should with the heat/weld be able to turn them out, then CHASE ALL the bolt holes, a LOT of anti-seize on the RING and the BOLTS on install
biggen
jefferson, ga
now how would i do this ...weld in (sorry pic is no where near the best) the only bolt that you can see that broke off is right side middle. the left side middle in there pretty good. the right side in the block about 1/4 in. and left side middle in there real good.......so how would i do the weld with those? if i can even do it still
jwaller
19
Columbia, SC
I'd just lay a nut as close as you can get it to the broken bolt and weld thru it. Has worked for me very well in the past.
73m819
314
gainesville, ga.
get some LEFT HAND drill bits,, both are weldable, make sure there is no kids around, other wise they may LEARN bad words
ODdave
lansing michigan
Both easy extractions if you are a good welder. I use this method on all of the aluminum head engines I work on. Mostly exhaust studs on triton ford engines and have never had one refuse to come out and I can say I have easily done over 150 studs. For the one below the surface use a mig to biuld up the shank on the bolt untill it starts to protrude from the hole, then set a nut on it and as said fill in the hole. Keep in mind your gonna need the welder hot so it all flows together for a strong weld.
KEEP IN MIND, Once you weld it your not gonna drill it , so make the decision you are comfortable with the first time.
swbradley1
Modertator
1,569
Dayton, OH
I would squirt some PB Blaster on the bolt wait ten minutes and then drill it if you go that route.
