Bit the bullet and bought a new box and sensor for the glow plugs system.
1 Patriot-of-many
Zimmerman MN
Got it at Erik's a little cheaper than Kascar, un did the negative ground on the batteries, checked all glow plugs, all were 3.2-3.3 ohms. disconnected canon plugs unbolted 4 bolts and removed box. Cleaned all the areas where the bolts attach to the box, put new start washers and a couple bolts on, put box in. Connected cannon plugs. Removed TSU after clamping hose, installed new one. Waited an hour, then connected negative ground. Waited another hour turned switch to run. WOOHOOOOO, wait light for about 8 seconds. started engine and did it a few more times, Apparently this box is smarter than the old one. It would only turn the glow plug wait light on for a couple seconds. After letting it sit a while, it again ran the whole 7-9 seconds on the wait light.
Anyway I was having intermittent issues with the old box, eventually after smacking it and playing with it it would energize the glow plugs but it was getting old, and don't want to trust this thing.... Took the old one apart, Looks like I can fix it. This explains the intermittent problem for sure..... What is this thing called? Looks like I can just desolder and replace it and maybe have a good spare box too. Can I assume this part is the same as the one on the left? Thanks!
1 Patriot-of-many
Zimmerman MN
I just looked on sites, None of them have the exact same markings as the ones on my board, How do I figure out which one to use? I never took electronics :( Are the numbers below the IRFP2907 just date codes and lot numbers or are they important?
1 Patriot-of-many
Zimmerman MN
Did any of that crap get on circuit board ?
If it did it will have to be cleaned.
Yeah, lots of black residue. What do you suggest for cleaning? I'm assuming here this is the only part that's fried, I don't know how to test the board except for putting it in and trying it.
cwc
145
Sweeden, KY
The numbers below the part number are lot/date codes, per the manufacturer's datasheet.
View attachment IRFP2907 MOSFET Datasheet.pdf
You can have one of these in your mailbox in a couple of days for less that $10, so it seems worth a try. Hopefully nothing else got overheated. There could be some conductivity to the deposits (i.e. short), so maybe scrub the affected area lightly with a soft brush and electronics/contact cleaner?
1 Patriot-of-many
Zimmerman MN
Thanks a bunch for the info. Didn't want to get the wrong part!
