Bleeding fuel lines M1028A3
hndrsonj
Senior Chief/Moderator
371
Cheyenne, WY
All right I know go to the manual! But, I have been looking and can't find the info I need. The 6.2 was completely dry-zero fuel anywhere. We bled at the filter on the firewall and have that air free. We can get to run great 2-3 seconds a time then dies from lack of fuel?? Where do you bleed the rest of the system? Do you just crack the lines at the injector or what?
1,827
At the injectors Jim. You will be cranking for quite some time. I'd suggest a real good battery charge overnight and then slave it off your deuce the whole time. They don't bleed quick. I do one or two cylinders at a time so I can get them tight before they suck up too much air. Watch overheating your starter too.
hndrsonj
371
Cheyenne, WY
Thanks Kenny, that's what I was afraid of. Does run great-though only for 2-3 seconds.:roll:
