BlizzardX23's Custom Cargo Cage
BlizzardX23
12
California
Well..I never got bows or cargo cover when I purchased the truck...and recently, I've been trying to come up with a design that will have more than just one function (like the standard cargo kit)...so here is the start of my new build!
The black line is just a representation...to give me an idea of interior space. I'm going for somewhat of a "SOFT M109A3" style idea...with the possibility of throwing up solid panels for when myself and our film crew goes out on location to shoot...gear in the back can be secured, dry, warm...a place to rest...since we will be out at night in locations like the woods and whatnot..
Last pic is what it would look like with hard panels installed
BlizzardX23
12
California
Since you are building it from scratch you might consider making it less wind resistant (I know it's going on a vehicle with the aerodynamics of a cement block but every little bit helps).
Valid point!
What are you suggestions? Like the big rig "sleep wings"? to deflect the air from hitting the box?
srodocker
68
Lacey, Washington
maybe make a cab rack. to help deflect some wind. like the big rigs but make it useful to store some tow straps or something not always used
going to do that myself whenever i get around to buying the materials
BlizzardX23
12
California
I want this thing to be a lego truck...completely plug and play style...Im sure the wind deflector could be quick connected as well
Maybe I'm going to have to purchase a large vinyl tent section...and make it work? =/
Loco_Hosa
Ethel, Wa
Instead of modifying the cab, you could also use two 45 degree angles in the front of your cargo cover to get some aerodynamics. Seems like it would look more "Correct" as a DEUCE, and would still be as functional, without loosing much interior space.
Either way, Im subscribed.
cbvet
20
Northwest (Knox) Indiana
One of my trucks has the steel "riot" box on it.
If I were building it from scratch, or had the ambition to modify mine, I would add an insulated bed over the cab, like most class C motorhomes.
This would free up a lot of floorspace.
BlizzardX23
12
California
a door on what?
I wanna build the cage for the "soft 109" feature after I find a cargo cover that will fit...but also be able to remove that and throw the hard walls on.
This is what I have in mind for the hard walls....I don't have a crane...or a place to store a shelter...so that's why I'm thinking of doing this in such a way that I can remove each wall separate...and store them flat against the wall in the garage
Danger Ranger
23
Roland, IA
Subscribed, definately do something aerodynamic up front, like a camper bed area up top, that quick attaches to the sides, then it could come off too...
