ehuppert
- 143
- 43
- Upstate NY
Still in the midst of my frame up resto! Beauty of a frame off restoration is that once the frame and parts are blasted and painted it's really hard to bolt any rusty crap back on the truck! My steering shaft was very ugly, rag joint wasted. Perusing the web, jeep shafts (used were expensive), brand new jeep shafts apx $100, so in a spending money moment i ordered the borgensen u-joint shaft!
Going to cut the piece down tomorrow, not a big deal. Question is, doesn't look like the thru bolt hole in steering column gets used? I'm assuming i need to drill a hole in the steering column side for the long set screw?
Understand why the shaft is long and needs to be cut down, but would be nice if they made the upper joint collar use the through bolt!
any BTDT's
Eric
any BTDT's
Eric
