Maybe not.If you put these back on your truck you will have scuffing issues as the diameter of these tires are significantly less than the others....
My Stalwart, a 5 tonne w/1400 x 20's, is diameter critical because of the direct driveline (per side, it does had a locking diff between sides). The EMER (a.k.a TM) spec., if I remember correctly, allows for 2” front to back and 1”side to side, at 30psi, with largest tyres on the back... Interestingly, the hull data plate allows for different pressures F/R.
A math study is something like this – If you call 1400 x 20’s a 48” tire the circumference is Pi*2*radius or Pi*dia = 150.72”. Buff off 1/4” dia and they are 47.75” x Pi = 149.935. That's .785 smaller around. 1% of 150.72 = 1.5” so the difference is about 1/2 of 1%. Not much, and much less the Stalwart’s spec. But the tires shown earlier are different. Only part of the tire got buffed away as they weren’t round to begin with. If, say, half of the 1/4" got lost seems like difference would be more like 1/4 of 1%.
A quick trip out with a tape measure shows the one pic above on right* (99% then buffed) was 154”, the middle one was 153 7/8” and the one on the left, the worst, was about 153”. That’s about 3/4 of 1%. Not much.
Also, for clarity, I had left out earlier that the worst tire was my spare. It got drafted because the 99% shown here was on the left front. That got pulled because it had been a real steering wheel shaker.
Also, increasing the pressure will increase the circumference. Does anyone know the TM Spec. for diameter variation? As I stated before, adding max air made irregular tires worse. Please point out any math errors. I’m sure it will go down the road just fine and don’t plan to fiddle with pressures.
Also, I forgot to mention earlier, the 99% came to me with more and it has a 2002 date code.
p.s. In my case towing a 28K trailer, with maybe 4K(?) tongue weight, made little if any change to the bounce.
p.p.s I thought these retailed about 8-$900 ea (not what I paid). Anyone know for sure?
p.p.p.s 28719 members and Paul still has the best avatar.
