EastRidge
- 22
- 8
- Plymouth Wisconsin
I needed to replace my master cylinder on my 54 M37.
I do have the front disc brakes.
Brake bleeding has been beat to death on line in all forums, but I thought I was going to rise above.......
After I did the swap, and I believe I bench bled the master cylinder correctly as it did develop pressure.
I have gone through 3 large bottles of brake fluid with the wife doing the pedal work. Always back to a 2 pump to get a firm pedal depressed about 2-3".
SO,......I picked up a check valve for brake bleeding,......and came up with the idea to run tubing back into the reservoir.
I pumped 10 pedal strokes 10x each bleeder, and produces no air bubbles.
Worked super slick, and lost almost nothing for brake fluid.
BUT I AM JUST BACK TO STATUS QUOE.
Thoughts, help?
Thoughts, help?
