brake chamber, unscrew or change
Finallygotone
26
South Louisiana
I am going to have to change one brake chamber on the read of the 5 ton, does it unthread at the bucket or would it be best to change the bucket and the pipe nipple that goes to the well hub.
simp5782
Feo, Fuerte y Formal
9,513
Mason, TN
You simply cage the spring can with the caging bolt and remove the 2 bolts on the clamp.
Finallygotone
26
South Louisiana
simp5782, I have done that to get it home and tied the lines, I got rear ended by a car, it must be change its broke, was asking if it unscrews for that pipe nipple or do I have to change the hole thing, thanks, Joe
simp5782
9,513
Mason, TN
The tube will unscrew from the brake spider. You have to remove the spring can prior to that though. Will make it alot easier
