fredrader
- 0
- 0
- Miamisburg,Ohio
Ok,I have had problems with my brake lights not working or working but dim and sticking on VERY dim...I decided to get a new 3 lever switch and in the mean time I bought 2 pressure switches..One new one and one used one..Ok I replaced the 3 lever switch and no help..I tested the wires that plug in to the pressure switch with brake pedal up and I have 25v on one side and like 3.5v on the other wire :banghead: I have helper press down on the brake and the 25v wire stayed the same and the other wire jumped to 10v..Tested it 10 times and the 24v wire stayed the same and the other wire never read the same voltage twice..So I decided to remove the pressure switch and replace it with one of my spares...It takes a 13/16 wrench for the switches I have for spares and the one on my truck takes a 1" or maby a little bigger..Anyway I removed the old switch and noticed that the threaded part that screws into the master cylinder was a lot smaller then the threaded end on my new switches :freaked: :banghead: ...So I proceeded to re-install my old switch and bleed the master cylinder but now I'm still w/o brake lights...I don't know why they just have a contact switch on the brake pedal or something...Anyway I guess I will have to try and find the correct pressure switch or rig up a contact switch..Any help would be greatly appreciated..
