brake pipe ???
MrAugust
england. uk
don the brakes today pipe changed and all the lot. bleed up the brakes... back to fornt but still have a soft pedal.... any ideas.. im hearing air in the pedal piston area but how the **** u get it out... i also noticed it ahs a hole in the internals ware mini air bubble were coming form is this to let the air out or do i have troubles in my pedal piston area..... :driver: i can hear the brakes all in and the fluid is threw and air free... im at a loss.....
Crazyguyla
124
Altus, OK
did you bleed the slave sylinder on the front of the airpack? If there's air bubbles comin out of thr master cylinder, then there's probably air in the line going to the slave cylinder.
MrAugust
england. uk
yeh i have bled the slave cyl plenty... .... but question is do i need the air pressure up to do it right?? and the air seems to be behind the pedal....i took a ltr of fluid out of each back and front brake... and no air on there... just dotn get a hard or firm pedal....
