Bringing the Deuce back to 100%
After picking my Deuce back up a week ago. I had a list of things that needed to get fixed. Coming home from work on Tuesday I got to add to that list. I got stuck in a bunch of traffic. Nothing like stop and go for 50 miles. Anyway by the time I got home the drivers front wheel was so hot you couldn't touch it. The other three were cool. And it was a bear to stop. So today I took the rear hubs off and found that the rear axle seals were shot. Brake fluid everywhere. I soaked the shoes in Isopropyl Alcohol. Cleaned and repacked the bearings. Put in new axle seals. Reinstalled everything and adjusted the brakes. Then moved to the front and adjusted the brakes there too. It stops so much better now. Just a few more things to do and she'll be back to 100%.
Good work getting it back to operational. May I ask about how long it took you to do the labor? Also about how much did you spend for new parts?
The labor took about 2 hours. The parts I ordered from Boyce about a year ago. Just figured I'd rather have them on hand if I needed them. You'll have to call around for the prices. Sorry I can't remember.
This evening I got around to a couple of the small things on the list. The drivers door hinges had a few busted screws and a couple loose ones. They are all new now and all of a sudden the door doesn't sag and it closes a lot easier. And I got around to fixing the passenger window. It used to only go down half way then jam. I took it all apart found the clip that fell off the forward track. Put it all back together and it works now too. Small steps maybe but they all add up to a better operating Deuce. Especially since I am commuting in it to and from work round trip 100 miles a day.
So here are the pictures. Today I fixed the head lights. Before I had no brights. I put in some free used truck light LED lights. The drivers side doesn't work quite right but it's better than I had. The upper portion works when it's on low beam. But when switched to high beam it turns off. Oh Well. Just one more thing to fix. I also fixed my pyrometer. It had a wire chafing inside the insulation. Simple fix. I will replace the master switch this weekend with the new one.
Here's todays projects. One I haven't finished yet but I'll get it installed tomorrow. I put on new ANCO wipers and built a box for my altimeter. I picked up a NOS mil-spec helo altimeter awhile back. I am finally getting around to mounting it. I made the box out of 2024 .032 T3 aluminum. With way more rivets in it than I needed but what the heck. I like playing with metal. I am going to mount it to the cab top with two aircraft dash lights. I am going to put the lights on a door switch. I really don't need the altimeter lighted up at night. But interior lights will be nice. They'll be green to match the ones for my dash.
Today I got around to installing the Altimeter. I put it in the left corner of the cab. I couldn't make it look right in the center.
I've had it as high as 5000 ft and as low as sea level. At the top of the Cajon pass on the I15 and the top of the grape vine on I5 it runs just as well as it does at sea level.
islandguydon
I would think a Garmin is the city boy's altimeter. Was yours self contained in the box you made..? :drool:
I left four air holes in the back of the box for air flow. The altimeter has a small air filter on the back so I don't have to worry about dust clogging the diaphragm. The entire thing is sitting in the box. It's 4 1/4 wide by 8 1/2 long. Not a bad fit and I riveted it to the frame support for the top.
Today I got back to work on the Deuce for a much needed fix. Awhile back I put in a seat from a Ford Aerostar. It's great other than it was blue. Friday at work the flight equipment shop helped me make some new seat covers. The bottom seat is completely recovered and it's sewn together so it won't slip around like a normal seat cover. The upper is pulled over and sewn together at the bottom. IT turned out pretty good for a guy that has never done this and learned how to sew on the fly friday.
Today I mounted a set of work lights on the bumper. Tomorrow I am going to mount 4 along the edge of the bed for work lights. I figure as much as I use this truck as a recovery vehicle a bunch of lights individually controlled will be an asset for those middle of the night phone calls "Can you come help me" or my favorite conversations that almost always begin with " What Happened Was" and usually end with sure I'll be there as soon as I can figure out where you are.
