I'd assume they are the same. The earlier trucks don't have the rubber donuts at the rear cab though... If I'm not mistakenIf they are the same as the earlier trucks they are around. Or you can use hockey pucks.
Correct. They didn't work too well anywayThey did away with the cab levelers in the c7 trucks.
NopeDid you find the a1 c7 tm?
Hockey pucks look a lot smallerI used a hockey puck on mine.
stack them?Hockey pucks look a lot smaller
All soft cab trucks use the same front rubber mounts.Will the donuts of an A0 fit the A1?
