cam gear removal???
Pappa-G
Central, MI
to remove the crank I've gor to remove the frnt plate. To remove the frnt plate I've got to remove the cam gear. The cam gear only has two holes for cam retainer access bolts. there is also no cam gear retainer bolt. Am I missing something??? <img src="emoticons/icon_smile_help.gif" alt="Help"><img src="emoticons/icon_smile_help.gif" alt="Help">
Pappa-G
Central, MI
Apperently it was a wildcat design. The gear requires a bearing splitter and a press to seperate. So I had to remove the lifters and remove the cam/camgear as an assembly. Just thought you might like to know.
