Canadian 5/4 ton in 1:24 scale
ScottG2005
24
Arkansas
Hello everyone I built this model kit a month ago and I thought I'd share it with everyone. This model kit is based off of a 1976 chevy military truck that were bought by the Canadian forces in 1976.
ScottG2005
24
Arkansas
I tried to keep the same colors the c.f. 5/4s had. I found the best kit to use would be the "revell big game country"model kit cause it has all the parts most model kits don't. How ever it doesn't come with skid plates. So if you want them you will have to custom make them. also the credit for the 2 photos of the real life 5/4 goes to the original uploader
ScottG2005
24
Arkansas
If you're building the same model kit. Don't glue the back of the cab to the rest of the cab Intel you finish the interior cause its the only way you can install interior in the cab I found it out the hard way real quick. Also don't use super glue. It fogs the windows up. If you get superglue use very little
ScottG2005
24
Arkansas
So now we go to the tires. These tires are cloned after the ground hog bias ply tires. They do not make the original style wheels that where on c.f. 5/4 tons
ScottG2005
24
Arkansas
Now you're getting closer to seeing what you're c.f. 5/4 ton model will look like now put the engine in the frame,put you're wheels on,glue the body down, that is if you've done the interior. I done a black interior(sorry no photo of that sadly). The original c.f. 5/4 tons had a tan interior(I think I might be wrong) with maroon bucket seats. Just use the bench seat it won't hurt how it looks cause some of the c.f. 5/4s had bench seats converted in them.
tbar123
24
enon,oh
Looks good so far! I always use Hob E Tac for windows. Woodland Scenics makes it. It dries clear and if you need to remove it you can. I use that stuff on a bunch of different things.
ScottG2005
24
Arkansas
Thanks for the advice man. I plan on building another in the future as a "signal truck" ill look at the glue you are talking about
tbar123
24
enon,oh
You won't be disappointed. That stuff is model making magic! You have to paint it on, Let it dry then apply. I use it for PE. mainly but it's great for all kinds of stuff. Keep the current build progress going.
