Canvas Top
Milsurp
Loveland, Colorado
Mine has begun to show signs of wear and tear. I have some sources available to purchase a new rag top but.... how difficult is it to actually install? My M37 is a 1954.
Thanks!
jedawson1
22
Murfreesboro, TN
Not sure, but mine was real easy to remove. The rope behind the cab requires a screw driver to push it off the tie down points. I would imagine the reverse to be pretty easy.
3dAngus
101
Perry, Ga.
I might be needing one soon. I purchased a number of HMMWV tops just to see if they might be cut and sewn to fit, but it turns out it might be easier to just buy one.
Will you share your sources with us?
Roller
50
North Lake, WI
Thanks!
Not that difficult. I bought a new cab cover from New Life Resource and had no trouble installing it myself. I had never put one on before and it proved to be fairly easy. Stand in the cab, throw the top over the winshield, thread the front of the top into the retainer on the windshield, pull the top back over the top bow, slide the sides into the supports, clip the tabs into the top side supports and tighten it up.
Frank
