Cargo Hook Capacity Anyone ??
rivercreek
Berryville, VA
I've been unable to locate any information on the weight capacity of the multiple tie downs located on the inside of the Deuce bed sides. Anyone happen to know? I've not had much luck searching TM's or SS so far. Any info would be appreciated. Thanks.
glcaines
2,729
Hiawassee, Georgia
I'm assuming that you are talking about the tie-downs located in the bed of an M35A3? These were added to A2 beds as part of the ESP program. I don't know the capacity, but they are fairly stout and very handy. I would simply use some common sense when tieing something down. I doubt you will find a spec.
rivercreek
Berryville, VA
Thanks for the replies. Yes, it's an A3 bed. I have a 4.5 cu yd salt spreader to secure in the bed and im having my doubts from the "common sense" aspect as you mentioned glcaines.. Without knowing what these points are rated, I guess I'd better err on the side of safety and install some D-rings on the floor... Oh well.
JCKnife
46
Kentucky
Can I see pics? I have often wished my A2 bed had tie-down hooks and have often thought about having some welded in.
quickfarms
25
Orange Junction, CA
Your common spence is right on.
That much weight needs to be chained to the structure and not the sheet metal.
