- 205
- 7
- 28
- Brenham, TX
At night, I could never make out the CAT 7155 transmission shifter gear numbers on my M920. They are lit up by four bulbs. I found that when the light switch was adjusted for maximum dash panel light brightness, the most I got out of the four shifter bulbs as a dim orange glow. The highest voltage I was getting at the bulb socket was around 11 volts. I did a little research and found a bulb #1048 that is rated at 11 volts and fits. The numbers can now be easily seen at night.
