ENCS_DEI
- 0
- 0
- North Carolina
FYI, recently got a M35A2 that was experiencing blowby with just over 1000 hrs on the engine. I found that No. 1 cylinder sleeve was scored along the front of the engine along the axis of the piston pin. After disassembly I found a bright mark on outside of sleeve and a raised dimple in the cylinder bore at corresponding location. Cause was improper removal of freeze plug during last overhaul. There is not enough clearance behind the left side of the freeze plug (as viewed from front of engine) and sleeve bore to drive the plug out with a punch. The TM gives procedure for removal but if your going to knock them out with a punch the front plug and rear plugs "MUST" be carefully driven out from the right side (as viewed from front of engine).
