Chains, Cables and NDTs
Opie
Salem, VA
While this may sound like a weekend fantasy to some of you, I'm simply thinking ahead to winter. I hear the NDTs don't fare well in light snow/ice, which is what I mostly expect here. I'm still dual wheeled in the rear, wearing 9 x 20" NDTs all around, and am unlikely to venture off-road with the white stuff on the ground.
The question I have is cables vs. chains, and single or dual tires in the rear? I've pulled the stub axle (without thinking of how I'll EVER re-install it) in the rear.
Thanks for your input. Now I just need to install the heater kit...
cranetruck
94
Meadows of Dan, Virginia
Wow, that's some avatar! May have to work on mine.
About the questions, could you be more specific? I live in your general area and have experience with the snow, driving in it, that is.
_______________________
Bjorn
MVPA 19212
1968 M49A2C modified. 1972 HIAB 765A crane and 1960 M756 pipeline truck bed.
11.00-20 NDCC singles.
M103A3 trailer.
"Some things cannot be made better, just differently"
CURRENTLY WORKING ON: Vehicle wiring, adding relays for headlights and turn signals.
Adding small fuel tank (starting and shutting down in cold weather) and installing heating coil in main tank for biodiesel/cooking oil.
n3uka
Beltsville, MD
So I am not the only one thinking about snow. Also wondering where a good place to get the chains or cables? What is good snow to drive and when should I stay parked.
Opie
Salem, VA
Well, on this page ( http://www.tirechain.com/9.00-20.htm ) the tire cables are less expensive and most likely weigh less than comparable cables. The new MILSPEC items I've seen are yet more expensive.
As I don't have the square-edged profile of standard over-the-road tires, and won't be going offroad in the winter, what would be adequate for me for the two to four inches of snow I can expect at anyone time here?
I guess my question really is whether cables will work on NDTs?
cranetruck
94
Full blown chains are a PITA on pavement. Speed 5 mph or below the vibrations are so bad. Don't have any experience with the cable type, may be a lot better in light snow on the roads...
Bjorn
