Charts defining AXLE Shaft ID by Physical Details like Length, Width, Splines?
ke6rwj
creating havoc one broken bolt at a time...
285
151
Alabama
I have several shafts that are new but can't find a number on them at all. Is there charts that would help to identify the vehicle variant that they will fit? Something like this would be very helpful when parts hunting at swap meets and shows..
Something like:
- Length: (measure by measuring tape with the shaft standing straight up...
- Width of shaft
- Spline count
Measurements are "Eyeballed"
Length
Width
Splines
HMMWV Model / Year -ish
Civilian Part Number
24.51.2527
271.2527
291.2527
- Other identification methods?
ideas?
-- Chris
Coug
4,764
Olympia/WA
If it is round at the differential end, then it's a 7 or 10k. can be used interchangeably.
If it has 3 flat sides, then it's a 12k.
then for the 12k shafts on the left is how the solid brake rotor and ECV/REV mount to, so smaller center round portion on the face. Right is for early vented rotors
To borrow a post from another forum
Re: 12K Half Shafts, large flange vs small flange
Post by Ted Gates » Sun Jan 27, 2019 6:55 am
There are at least 2 styles of 12k, 12" vented rotors. Wilwood 12" rotors use small flange and has a different offset than the other vented 12" rotors.
I've built all three 12k types:
If you are building a true REV, then you require small flanges on differentials, Wilwood vented rotors, 12k small flange halfshafts.
If you are a building an ECV or M1114/13 or early M1151/52, then small flanges, 12k solid rotors, small flange half shafts.
If you are building a 12k A2 truck, then large flange, 12k vented rotors, large flange half shafts.
FYI, 10k trucks use 10" vented rotors and large flange 10k half shafts
Mogman
10,496
Papalote, TX
Something like:
- Width of shaft
- Spline count
Length
Width
Splines
24.51.2527
271.2527
291.2527
ideas?
-- Chris
If you are talking about half shafts the shortest one would be LF, the longest RF and the intermediate would be rear R or L.
Coug listed an excellent way to determine load capacity.
ke6rwj
285
151
Alabama
Thanks for everyones input, I did the following chart to put in my maintenance records.. I know it seem trivial, but I tend to do documentation so its useful for someone with limited knowledge of the subject.
Does this look correct? Terminology? anything else I should add?
