Cheap and easy shift indicator fix...
linx310
Well my shift indicator was missing the actual indicator part...not sure how it got broken off but it was like that when I bought my M1009.
When I rebuilt the dash yesterday I took it off and used a small dremel to cut a notch and glued in a colored paper clip piece to make a new indicator.
Better then spending $30 at LMC for the part....
taildragger03
Well Done! The simple solutions never end!
I used an orange tooth pick to replace the needle on my fuel gauge a while back.
doghead
4 Star General /Moderator
Hmm, this could work two ways...
Next time I drive home in the CUCV from the Greasy Spoon Diner, I may just snap that ole fuel gauge needle right off and use it for a toothpick! (never thought of that before this thread)
armytruck63
Good thing CUCV's are new enough that you don't have to worry about any Radium in the gages!
baddy3
i gave up trying to repair the shift indicator, as doghead stated, it would work for a few days and go...i got used to counting the gears while shifting so i don't even think of it now, however the wife is the one who often hits the garage doors. ;-)
HogHunter
I had a problem with my indicator that was causing it to slip off the column. The cable would go behind the column when I hit drive. I solved it by drilling two small holes and mounting two pop rivets with washers holding the cable down. It is now tight enough to point correctly.
