HASSON1911
- 24
- 18
- roseau/mn
Hey guys as some may know I'm going to check a M923 and a M925A2 out this tues, just doing a little double checking for things to look for on these trucks before purchasing one. So I thought why not start a thread to help others since there seems to be a surplus right now on GL. As I know I'm probably not the first who started out with a deuce and want something bigger, but have never seen on quite like these guys. Sure I have seen big semis, but not like these boys. So Im starting a list of what I will be checking out when I go down there, if you feel that I have missed something or have a secret spot to check your more than welcomed to post.
P.S. I have spen an hour on google looking for something such as this with no luck feel free to advise me to a current thread if one exist and this one can be taken donw. Thanks- Jake
1. Tie rod ends, for excessive play
2. air leaks / hyd. leaks
3. driveshafts crosses and u-joints
4. leaking wheel seals
5. gear lube leaking from input shaft and output shaft on drive axles
6. lights turn signals brakes four way flashers
7. horn and wipers
8. Properly adjusted air brake, check for over camming
9. check ctis
engine compartment
10. fluid levels
11. belts for tension and wear
12. oil leaks around heads
13. fuel leak around IP
14. Air electrical gauges
15. Make sure it keeps air in accordance to MN DOT standards.
7. horn and wipers
9. check ctis
engine compartment
10. fluid levels
