Civy Trailer Light Option
huntnfool
sevierville tn
This is my solution to be able to pull my 18' trailer with my deuce or a truck with a 12 volt system. I ran a separate wiring harness and connector to a pair of lights that I had left off of a m101. I fabricated the mounts and wired the harness so that I am able to remove the 24 volt lights when not in use. Just pop the 12 volt tail lights out, unplug the 2 wires on each side, unbolt the 24 volt lights and brackets, pop the 12 volt lights back in and you're done. It takes under 5 minutes to swap them out. I needed to come up with a solution to the problem of not being able to tow the trailer with either of my trucks when Mother Nature gave me a push by dropping a oak tree on my 3/4 ton truck during a wind storm.jakes pups 1-11-11 004.jpg
sterlun
10
Morganton, GA
That's a good set-up as long as you have a military parts trailer lying around. Still like it though. Just curious, why would you swap out the lights every time? Can't you leave them all on the trailer and ready to plug in to whichever vehicle applies?
Your 3/4 ton was sweeet! I love how out of the whole tree line that was the only one that felt like falling. You gonna sell it?
huntnfool
sevierville tn
I could leave them on, but they kinda stick up in the way and I don't want to damage them. I will leave them on until I repair my pickup. Yep one tree out off a thousand falls and it centers my truck.aua
