Clutch Adjustment
ecostruction
York, PA
Gents,
I've searched a bit and printed out the appropriate pages from the TM 9-2320-361-20 for adjusting the clutch. My clutch seems to grab pretty late when letting it out. I guess this means it's "high". It also is hard to get into gear when cold. Well, it's hard shifting from second to third and third to 4th. Once warm though, it shifts much better. This is the first winter with my trucks. Nothing else with the clutch seems to jump out. Once the pedal is released the entire way, it grabs nice and tight. But haven't tried under heavy load yet.
I'm no mechanic, but am handy and do a lot of work myself. I still have questions though on how to adjust the clutch. I'm still a little confused as to the exact procedure. Any and all help is greatly appreciated. I'm wanting to make the resistance further into the travel of the pedal, i think. More where it should be i guess.
Regards and Happy New Year!
Jake
1,161
The basic idea is to have 1.5" to 2" of free travel on the clutch pedal, when depressing, before it encounters the resistance of the throwout bearing trying to push the fingers of the pressure plate in.
What you will need to do is get under the truck, and locate the adjustment rod for the clutch. Remove it and loosen the locknut on the end that faces the front of the vehicle. You can then spin the adjustment in and out. To reduce free play, spin the adjustment out and vice versa (I think I have that right). Put the locknut back on (or retighten it) and reinstall. This is a good time to wiipe a little lube on the clutch linkage. Reinstall, test pedal. PS Magazine here on the site has a great visual aid for freeplay measurement.
http://www.steelsoldiers.com/index....15_M35_PM&name=gallery&include=view_photo.php
doghead
4 Star General /Moderator
1,192
NY
For the stiff shifting, have you drained, flushed and refilled your transmision with new oil(GL1)?
bigmike
363
Dixon CA.
what about the 3.25" adjustment?
My truck engages right at the top of the freeplay 1.5-2.0".
I was reading the TM 2320-361-20 pgs 320-322 and see that the arm to the throw out bearing should be 3.25" from the bolt hole CL to the trans. mounting flange.
Mine is about 4.125" and although it seems to grab at the top of the pedal...she works fine. I also was wondering if the clutch should grab more towards the center of the pedal travel.
Do I need to worry about this and if so, why?
thanks,
dirtyfingernails
Gainesville, FL
RE: what about the 3.25" adjustment?
Big Mike,
Mine is exactly the same way. I've been told that this is normal. Mine engages great, doesn't slip, and will stall the engine in 5th gear from a stop with the brakes on. Until it starts slipping, I'm not going to tackle it.
Steve
Rattlehead
Michigan
My clutch free play is adjusted correctly, and has always released toward the top of the travel. This question has come up before and I don't think I ever have heard someone say that theirs releases close(r) to the floor. Any other vehicle with mechanical clutch linkage and I would suspect that the clutch is getting worn.
