clutch plate surface area
SuperJoe
Mesa, AZ
i have finally removed my transmission from my burnt multi and was surprised to see how little surface area the clutch plate actually has. with aprox measurements it has about the same area of my geo metro plate. the pressure plate has far more clamping force so i am only comparing area here.
couple things i have questions about:
is this the standard plate that is in kinda a star pattern or did someone at some time put in a bare essentials kit of some sort?
also i have never seen a plate that was not a complete circle. is this star common on larger applications?
also what do you think the aprox weight for everything in the second picture would be? i want to palletize it so its easy to move to the "never be used again parts recreation" in my yard, but i dont want to be half way there and have the pallet give up and dump my mess all over
thanks
Joe
1,187
Two things you should use more often, The shift key and your TM.
ODdave
41
lansing michigan
Way different than your geo.
You have to keep in mind the diameter, And the button style of clutch has much more holding power than a disk because the force of the pressure plate is not spread out of as much of an area.
You will notice that the buttons are made of a metalic/ceramic material and not organic like disks.
Button style are more durable and hold more than disks but in light vehicals they tend to chatter and are not as driver friendly so they are not common in trucks 1-ton and under.
m816
Chatham, NJ
The clutch disc is standard. The fly wheel needs to be surfaced as well as the pressure plate. the assembly you have displaued is only about eighty lbs. the pallet will be fine. I have all my parts in a card board box. We are doing a clutch job right now and total cost is about three hundred bucks. Yours may be more. I'm clling in some favors for this job. We have the engine/trans powerpack out so we thought it wa a good time to do everyting
m816
Chatham, NJ
to Od
About your avatar, what is the lass going for ?I hope she was rewarded with her efforts. Just my observations
