cold trip to get fisrt deuce!
appellandscaping
delta, PA
my dad and i went to get my firs deuce. the p side window broken out and snowing lightly. i love doing this kind of stuff with my dad. anyway it runs great but a few probs the front end shakes going down the road, what could it be?
rivired
federal way washington
u should specify if it a speed related shake or occasional or random ect... to be better helped..but u should just do a good look over first...rim packed with mud...bent rim....cracked separated tire ect..
powerhouseduece
Pasadena, Md
Is that you or your dad in the pic? If its you, then the appel dosent fall too far from the tree... Its a good looking truck! It might be as simple as a bad tire for the front shake but you'll have to jack the front end up and give it the good old shake test to check everything.
dburt
9
NE Oregon & SW Idaho
If your tire tread on the front tires is worn unevenly, it could be tire balance, bent rim or alignment. In cold weather the bias ply tires "take a set" and end up with one section flatter then the rest of the tire, (from where the bottom of the tire set on the ground) which leads to a very rough ride. I put radials on the front of my deuce to get rid of the shaking and bumpy ride, also it makes for easier steering too!
jcappeljr
27
Delta, PA.
Nothing like a cold ride home in your first deuce,I bought a 5 ton about 6 years ago.I drove home about 70 miles in the snow with no top. I dont know if I would do that again.
