Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Ok Ive read this thread over a few times. I'm a simple construction worker, so please keep this in mine. The A2 spicer has a 5th gear ration of 1:1. The A3 4th gear has a ratio of 1:1. The A3 has bigger tires, so why doesn't it go faster? Is it the axles that are geared differently?
Ok I dont know where I got the 3053 being 1:1. So my final conclusion (that was summed up in about post number 2) is that getting the 3053 back in with the same tires or bigger would give you a better top end without the OD kit, or would you still need toms OD kit?
you wouldn't need the OD kit, because the 5th gear in the spicer already HAS an OD gear.
If you REALLY wanted a taller OD gear, then you could do both, but MY Cat3116 wouldn't have the balls to push a truck along with gearing that tall. It barely climbs the hill leading up to my house with the Allison auto in second gear
the 3116 can be turned up to more power than the multifuel. with a stock 3053 you will have some more mph, but not much. with gear kit you will have 67 mph at 2500 rpm. there is a mph/rpm charton the od gear website for comparason.
I have a GMC Topkick with a bad 3116 and a good 5spd. trans with recent new clutch. Don't know if it is an OD but if you are interested shoot a PM and I can get model numbers, etc. to see if it would meet your needs.
no, i am refering to this thread. most OD trans are just that, OD, while the 3053 with my gear set is more like another gear which is what is needed with such a low rear ratio. i am very surprised no one has done this swap, i think it would be the best of both worlds.
Ok, I understand now. I was just confused because post #48 didn't mention a flywheel. If I was to go back to a Spicer I could also install a PTO/Winch. Starting to sound more and more attractive. My next step though is to talk to a local transmission/diff/gear shop to see what ideas they may come up with.
keep in mind that no one has ever found a trans with this much OD that will fit in the short space available. given that you would spend, $3000 doing this, (a guess) it would take some time for payback, but driving at 65-70 is much nicer than 48.
I hope to take my A3 from Atlanta to the family farm in south Georgia multiple times a year. The trip is 240 miles which means that I could make the trip in about 1.5 hours less time (each way) if I could travel at 70mph. I would rather take that time and use it around the farm/river/ponds than to use it absorbing the scenery along I-16 (I have made that trip hundreds of times and there is nothing along that route that I haven't already seen or care to see). To each his own though.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
