charlesmann
- 713
- 93
- Temple, Tx
I did use the search function, but couldn't find anything within the realm of my inquiry. If it has been posted already, i missed it and sorry to bring up the "beating a dead horse" topic.
I was contacted by a local wrecker company and he changed his mind and offered to sell me 2 936A2 wreckers for $13.5K. he bought 1, brought it home on a wrecker of his, but did something and burned out the xmsn. he bought a sec, to rob peter to pay paul and offered to tow the non running wrecker to my house for free. That'll give me a LOT of high $$$$ parts to keep 1 running while I'm saving up $$ to repair/replace the conked out part/s. I know iv got a bad xmsn, 1 tire and the boom lift cylinder. the cylinder, i can probably repair, tire, unsure yet, haven't seen either truck since I'm in canada working my first 3wk hitch with my new employer and won't be home till late jan.
A brief story as to why I'm buying the trucks. Iv dove into a building a wide cut sawmill that'll handle logs up to 78" wide and iv got several logs that weigh in around 6000+ lbs. I loaded and transported them home with the use of a log arch and a 12k winch on my 24K gooseneck. my tractor doesn't have the lift power to load them on my mill, but didn't know that till i got the home and scaled the load. i plan to locate more large old growth to justify the sawmill build and the purchase of these trucks. with this truck, i can load the logs on the mill, put a set of axles under my mill, use the crane to pick up the saw head carriage and turn it sideways to transport it down the road, then repo the head back into operational position, rinse, repeat for the return trip home. I was also thinking of adding a set of rear QD hyd points and get a pup dump trailer to haul rock and such to my house or to my farm.
I would like to convert the whole truck over to 12v dc, for jumping starting purposes from my p/u tck, connecting a civi trailer, be it my current ele. brake trailers, or buying an airbrake equip trailer. plus ease of replacing common use/wear elec parts that go out from the local parts houses (napa, o rileys, frtliner, kw, pb, international)
Is even possible to do a complete elec sys. swap over that is financially and logically feasible?
thank you for your time posting a reply.
