- 2,110
- 557
- 113
- Davis County, UT
I'm a bit concerned with the high oil pressure readings in my 1972 M35A2. The engine is a Continental LDT-465.
After an oil change, a split upper canister gasket (over tightened operator error), and a bunch of oil on the engine/drive way I decided that it would be worth my money to purchase a spin-on oil filter conversion kit, if anything, to greatly reduce my chances of screwing up in such a fashion again.
I feel a bit foolish for not really making note of what my oil pressure was previously (I know it wasn't low or high, but I cannot remember a specific number). With the conversion kit installed, I run about 60 psi at 900 rpm (idle), and 80-90 psi on the highway (2100-2400 rpm). My gauge will read from 0 to 120 psi.
The filters are Wix 51458, rated at 11-13 gallons per minute, 21 micron.
I'm a bit confused by the TMs though.
Page 1-33 of TM9-2330-361-20 lists the oil pressure of: Idle @ 200F 10psi min; Full Load @2600 40psi min, 75psi max
Page 1-11 of TM9-2320-209-10-2 agrees pretty closely to the previous TM, stating:
"Normal oil pressure with engine running at idle speed is about 10 psi (69 kPa). With engine running at road speeds, engine oil pressure should read about 45 to 60 psi (309.275 to 413.700 kPa)."
"Some engines have normal oil pressure readings between 40 and 75 psi (275.800 and 517.125 kPa) at road speeds..."
Page 3-39 of TM9-2320-209-10-1 however shows that just after warming up the engine at 800 rpm, the oil pressure gauge should show between 30 to 40 psi (if I were to guess, this was probably about what my truck ran at before while idling. However, as I said, I foolishly did not take note of it before
Are these TM differences purely the difference of the type of motor? And do you think that the spin-on oil filter conversion kit I got may damage my engine?
I have driven the truck about 20 miles, and let her idle for 25 minutes with no abnormal sounds or temperature readings.
