Converted my gauge cluster
csramsey640
Central PA
Note #1 do not attempt this unless you have tons of patience and tons of time.
I removed the instrument clusterfrom my 86 m1008, and installed one from a civi GM that has gauges for oil pressure, water temp, and alt. In place of the clock, I added a second alt gauge.
They all work fine, however its far from a plug and play. A few of the wires crossed color to color, a few others changed color between factory harness and pigtail, and I believe the 4x4 light wire, had to be re-wired altogether to another terminal. Also changed the sending units for water and oil.
I always hated dummy lights. Id rather see, or atleast be fooled to believe that I have oil pressure.
csramsey640
Central PA
:oops: Ill get some pics posted asap. Well my wife will, because I have no idea how to get them from camera to computer. :lol: Ill even see if I can create a diagram.
CompoundCuckVee
New Hampshire
I concur I'd love to see some pics! I've been thinking about this since I got my M1009, I figured it would be a chore, but I'm with you, I'd rather see a gauge then a bulb. You can at least get an idea of what's happening under the hood from behind the wheel.
truck0590
Manassas, VA
I also would love to do this. Diagram would be awesome. I have a gauge cluster with a tach that I've been holding on to in order to one day figure out how to hook it all up.
Truck
Mike_Pop
NJ
:ditto:
nopics
I would also like to see pictures and a diagram. I've got a few gaugues that I would like to swap out on my dash as well.
