Glockfan
- 16
- 18
- Brigham City, Utah
I know that there are a few threads regarding lifting these vehicles. I plan to post a lot of before, during, and after build pics. My m1031 has just over 18,000 miles on it and the truck is in good shape. Getting rid of the utility body is kind of bittersweet for me. As cool as it would be to load the truck up with bug out gear, I just think the standard pickup will be more practical for me.
A couple pled of months ago, I secured a civy 8' bed from another SS member here in GA. This is a dual tank bed and should be perfect. I've managed to trade for a brand new set of Wrangler Military 37x12.50 MT/R's on new 24-bolt HMMWV wheels. In the interim, I am going to be using 3" spacers to address the backspace issues using the HMMWV wheels. I may later convert to DRW hubs up front if the spacers don't work like I want them to.
i am working with Chris Holick with Offroad Designs out in Colorado to put together the lift. My buddy owns Bulldawg Musclecars in Cartersville and his folks are helping me with the conversion.
Spacers are here, the suspension components are hopefully in route. Here is a list of what I ordered from ORD:
GM Dana 60 Front U-Bolt Kit
Greasable Heavy Duty Front Shackles
6" FR EZ ride 73-87 Springs / Special Bushings and Sleeves
Greasable Main Eye Kit for front eye of aftermarket front springs
Swaybar Correction/Disconnect System
4" 1-ton Shackle Flip Kit
2" Suspension Lift Block
3/4T (14B) upper ubolt plates for rear suspension
3/4 and 1 Ton (14B) Rear U-Bolts For Spring Lift With 3,4" Blocks
14" pair Bilstein F3 ORD SD Shock
14" pair Bilstein 5125 Shock
10mm GM Brakelines - through 6" lift
2" Drop Pitman Arm / 4wd Box
D60 ARP High Strength Studs (4) for Steering Block Applications
D60 Steering Block
Do you guys see anything that I need to add to the list? FYI- I have the utility body, PTO Generator, and air compressor for sale over in the classified section. I may be asking too much money for the stuff so I'm open to offers if anyone wants it.
plenty of pics to follow!
D60 Steering Block
