Convoy Light Help
tklm539
Bolton Landing NY
Man I am in need of some advice. This convoy light is killing me.
I ran the wire harness exactly like the directions said. Hooked 16a to
16 on the floor high beam dimmer switch. Ran the harness up to the
light and the ground to the frame. No dice, no light, no spin. I have
the running lights on and new warning switch on. High/low beams work,
dash lights work, running lights work, no convoy light.
Any advice would be great, I have re done it four times and still nothing. Is there a different, non official way to do it? I am only using one light if that matters.
Thanks
Tom
acetomatoco
9
Take the light assembly off and bench test it after you determine that you have power to the top of the umbilical cord...
acetomatoco
9
measure center to center on the holes and it will give you a clue... they are a lower cost version of the ones the ring mount uses.. The light problem was corrected when the ground was established...
Crazyguypa
windsor, Pa
TNJMurray used to have some for about $350 a set but he may be out of them as the picture is not on the website currently. I would call and check though
MasterChief
brownfield Maine
I just wired mine directly. I grounded to the frame and supplied power with a 50A toggle switch on dash using a 10A inline fuse. Works well! BUT you must remember to turn it off as it is not tied to stock lighting system. Then again.....Hard not to notice you left a STROBE LIGHT on!!
73m819
327
gainesville, ga.
On the 819, I wired into the hot lead to the wrecker work lights, no need for head lights on, If the bat. is switch on, the beacon lights can come on, a lot easier wire then whats called for, for you non wreckers owners (not everybody are as blessed as we are), you can tap into the hot wire to the heater switch
