- 10,350
- 74
- 48
- Meadows of Dan, Virginia
Moving right along from one task to another, finding more and more work on the LDS465-2 engine.
Now, I'm past the injection pump, radiator, drivebelts, idler arm, compressor pulley and starting in on the old 2-inch coolant hoses. The projects are piling up, layer after layer. Not complaining, just explaining.
So next question, since the only way to install this particular part of the cooling plumbing involves sliding the hose onto the tube, rotating the tube into position and then slide the hose back onto the nipple on the water pump, I'm wondering if there is a suitable lubricant available to prep the tube and make the sliding part easier or even possible? Silicon dielectric compound comes to mind....
The TM makes it sound simple....
