aleigh
- 49
- 48
- Phoenix, AZ & Seattle, WA
Working on the (other) LMTV
Well last night I took the LMTV out to the grocery store (ha!) and noticed in the parking lot that it was spraying a fluid on the inside pax side wheel well. I thought it was hydro or maybe a oil leak - oil level was good, coolant was good, so I drove it home. When I got home ten or fifteen minutes later, all the coolant had departed, or anyways the tank was empty. Temp gauge and all that was normal on the trip home, although I am not sure what the temp gauge is actually measuring (e.g. an empty coolant line vs. the block temp).
What is that they say, start worrying when it stops leaking?
It sprayed all over everywhere so I need to clean the engine off and run some water through it to try to see where it is leaking. At first glance it looks like maybe one of the fittings on the front pax side of the engine.
Have I ever mentioned how I really wish I had a remote start/kill switch like an A1? Climbing into the tipped cab is stupid even with a ladder. I also noticed when I opened up the tank there's a lot of scales in there, around the filler. It looks pretty nasty actually but the rest of the tank looks clean. Not sure if it just collects in the neck because there's a void or what. I've never had to open it before since I would just normally check the sight glasses.
