Fuel Strainer Gasket?
Would I be correct in assuming that the gasket for the fuel strainer canister is the same as the one for the fuel filter canisters? I'm cleaning the fuel system before I try to fire up my new mep-002a. I had already ordered the new FRAM filters but when I pulled the strainer canister I found that the gasket was damaged.
m-35tom, were you able to get the SP101489 gaskets from wal-mart? If so, did you order them online or at a store?
Though it can probably be reused, I'm also going to look for a new brass washer that goes under the acorn nut on the strainer canister. Has anyone found a good source for them?
